found my spindles...
Old Dec 17, 2005 | 04:09 PM
351foxstang's Avatar
351foxstang
Default found my spindles...
found a 78' mercury monarch with 5 lug discs up front. 50$ for the pair. it will be fun removing those in the snow monday morning.
anything else i should pull from the car to use on my 67'?
thanks,
carl
Old Dec 18, 2005 | 10:57 PM
RJM763's Avatar
RJM763
Default RE: found my spindles...
I got spindles from a 70 cougar. I would recommend getting the brake lines because of how the brake hose attaches to the calipar might be hard to find. calipars are good to have as a core.
If you have not already done a google search on the disc brake converstion you should find some articles on it and they recommend what to get while at the junk yard.
good luck
Old Dec 19, 2005 | 05:57 PM
351foxstang
il get the calipers if they are cheaper than the auto zone core charge. thanks for the info on the brake lines, i will print out the article on the conversion for when i go to get them.
Old Dec 22, 2005 | 12:31 PM
rgormansouth's Avatar
rgormansouth
Good day, good find , don`t know if you realize you need tie rod ends/ outer ball joint to match off the car to. It is different tie rod then what on your 67. Of course all your wheel bearings will be 78 application.
Old Dec 22, 2005 | 02:38 PM
351foxstang
yup, i had read some of the articles on here a few times and i think ive got a good grasp on what i need to do. ill be bringing the spindles and inner tie rods with me to the parts store when i go to get the other parts i need. this way everything should bolt right in, hopefully.
thanks for the help,
carl
Old Jan 6, 2006 | 08:27 PM
351foxstang
forget this. after 3 trips to the junk yard, these parts are not coming off the car. [&o] im gonna order some of ebay the extra money is worth the hastle. once i get the car rolling again i will be bringing the car to my grandmothers garage and will start my custom rear frame/suspension and front clip rebuild. [sm=badbadbad.gif]
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
Dokilar
15
Oct 16, 2015 08:13 PM
KingRando
Oct 2, 2015 08:06 AM
Drastang
Sep 30, 2015 03:48 AM
