Starting with new carb.
Old Feb 15, 2006 | 10:12 PM
  #21
THUMPIN455's Avatar
THUMPIN455
Default RE: Starting with new carb.
You could just move the wires on the cap instead of pulling the distributor out. I drop them in and hook the wires up from TDC when I build engines.
Old Feb 15, 2006 | 10:18 PM
  #22
Soaring's Avatar
Soaring
I ♥ Acer
Pull #1 plug out. Stuff a rag in the hole. Turn the engine over until the rag pops out. That is TDC. If the #1 wire points to one o'clock, then you are set. If it points to 7 o'clock, you are 180 out.
Old Feb 15, 2006 | 10:21 PM
  #23
tylerdru's Avatar
tylerdru
i Am 180 out. Do i just take the distributor out and play with it to get it back in the right way?
Old Feb 15, 2006 | 10:52 PM
  #24
Silver Ponys's Avatar
Silver Ponys
You are making sure your #1 clyinder is up? The distributor will point at the #6 cylinder or 180 out every other time the balancer is at tdc
Old Feb 15, 2006 | 10:59 PM
  #25
tylerdru's Avatar
tylerdru
Okay, so i put the dizzy in while i am at TDC?
Old Feb 15, 2006 | 11:36 PM
  #26
Silver Ponys
Yes but make sure the 1piston is the one up. When the damper shows tdc it could be the 1 or the 6 cylinder that is on its firing stroke. If your 6 piston is up just install the distributor so the rotor points at the 6 wire instead of the one wire
Old Feb 16, 2006 | 11:37 AM
  #27
THUMPIN455's Avatar
THUMPIN455
It depends on which valves are open since both 1 and 6 will be at TDC at the same time. You want #1 to have both valves CLOSED, that is TDC on compression stroke.
I guess you arent reading this anyway. I will stop coming in this thread. 25+ years experience must not count for much.. Have fun with it Tyler..
Old Feb 16, 2006 | 03:47 PM
  #28
tylerdru's Avatar
tylerdru
thumpin, I was reading your replies. You helped me realize that i was 180 out. and i will use your advice more today. I am off from work.
Old Feb 16, 2006 | 04:45 PM
  #29
tylerdru's Avatar
tylerdru
Okay the dizzy is in the right way now. I will be attempting to start it up again later. I have some work to do right now.
Old Feb 16, 2006 | 08:31 PM
  #30
tylerdru's Avatar
tylerdru
Okay now the carb is backfiring. Just a second ago a flame shot through the carb[]
I think a little too much gas got into the carb when i was playing with the linkages.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
