Creaking Convertable
Old Aug 14, 2008 | 12:07 AM
KDL1's Avatar
KDL1
Default Creaking Convertable
We have an annoying creak in the framework of our 05 GT top. The lower sport springs we had installed have just made it worse. It doesn't matter if it's up or down. The only thing that somewhat quiets it is when the foam cover is on the top when it's down. Any suggestions would help as the dealer doesn't have a clue.
Old Aug 14, 2008 | 07:50 PM
ewgoetz's Avatar
ewgoetz
get a can of white lithium grease and spray all the joints to start out.
Old Aug 24, 2008 | 09:49 PM
kc5mhb's Avatar
kc5mhb
Does this TSB sound like your problem?
Convertible Top - Tension Cable Tick/Pop/Rattle
TSB 07-20-3
10/15/07
CONVERTIBLE TOP - TENSION CABLE NOISE -
BUILT BEFORE 12/1/2006
FORD:
2005-2007 Mustang
ISSUE
Some 2005-2007 Mustang Convertible vehicles built before 12/1/2006, may exhibit a tick, pop, rattle, snap, creak type noise that sounds like it originates above the front door glass area and/or convertible latches. The concern is caused by a stick/slip condition between the cable and the top. The cable runs from the number 1 bow to the number 5 bow and maintains the shape of the window opening. The noise resonates through the cable to the number 1 bow.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Replace both convertible top tension cables with revised service cables. The revised cables are incased within a teflon tube to prevent stick/slip to the convertible top material.
1. With roof in the closed and latched position, stand outside the vehicle with thumb placed under outer seam approximately 12" from the front edge of the convertible top, pull seam slightly outward/upward and release while listening for cable noise.
a. If stick/click, rubbing noise is heard go to Step 2.
b. If no noise is present continue with normal diagnosis.
2. Replace both convertible top tension cables per Workshop Manual, Section 501-18.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
072003A 2005-2007 Mustang 1.5 Hrs.
Convertible Built Before
12/1/2006: Replace Both
Convertible Top Tension
Cables, Includes Time For
Diagnosis
DEALER CODING
CONDITION
BASIC PART NO. CODE
7652806 41
Most dealers don't have a clue when it comes to tops. They sent mine out 4 times and had 2 tops replaced before the top people got it right. Then they tried to tell me that I put the top up while the car was in motion and it bent the arms. That is impossible due to a sensor that prevents the top motor from operating while the vehicle is in motion. I had a defective top assembly which by the way was also a TSB for my vehicle.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
