Top pads
Old Feb 4, 2010 | 08:45 AM
Duspan's Avatar
Duspan
Default Top pads
I just picked up a 89 lx vert that has a new top on it. The person who put the top on did not replace the pads. The pads are tearing where one of the pivot points are. Is there any way to replace the pads with the top on, or can I put something between the pad and the frame to stop this from happening?
Old Feb 4, 2010 | 09:08 AM
7 UP Mustang's Avatar
7 UP Mustang
I had to have my 1990 LX Convertible top replaced cause the back window was broken, and the top needed replacing. Are you talking about the pads between the top and the folding mechanical top parts? If so I am sure they should have been replaced with the top. Mine was in good shape so the shop used them again.
You might be able to unlatch the top and take the tightness off of the frame, and work something in there to protect the top. I am not sure what would work unless some heavy duty cloth. You might be able to secure it with black RTV to keep it in place when the frame moves over that spot. . Good luck!
LARRY
Old Feb 4, 2010 | 12:55 PM
Duspan's Avatar
Duspan
Yeah, I am talking about the pads on top of the frame on the inside. I guess I will try to find something to put in there. If I needed a new top it would not be a problem, but I don't so.....
Old Feb 11, 2010 | 06:30 PM
ryan1994mustang's Avatar
ryan1994mustang
on my 94, the pads are stapled in, between the top and the frame. the top is also stapled all the way across the top of each frame rail. not sure how easy it would be to get something between the top and the frame without taking out all of the staples holding the top in.
Old Feb 24, 2010 | 07:09 PM
sinister99GT's Avatar
sinister99GT
i have a auto upholstery shop,its a lot of work to replace them. the top would need to come off to allow you to staple them in place.you may be able get by for a while by useing contact cement and glueing some black canvas from the rear bow to the next bow forward over the aera where it is wearing.
Old Feb 25, 2010 | 10:23 PM
Duspan's Avatar
Duspan
Sinister, I was thinking of doing something like that. I know where some kevlar is I could use.
Old Mar 16, 2010 | 10:16 AM
kc5mhb's Avatar
kc5mhb
What about the fuzzy side of some wide velcro? Thats what the top shop did on my 07 on the 4th bow at the base. Something was causing the top to pull and get cut there and they used the soft fuzzy side of industrial strength velcro to cover the area.
lincolnshibuya
Jul 5, 2020 03:05 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
