CONVERTABLE HELP!!!
Old May 6, 2010 | 03:52 PM
greg2missy's Avatar
greg2missy
Default CONVERTABLE HELP!!!
I stored my wifes Mustang (02 V6) for the winter,When we got it out of storage, it now LEAKS at the back passernger side. No holes or rips found. Is there a way to "adjust" the roof or am i screwed????
(It didn't leak last year)
THANKS.....
Old May 6, 2010 | 09:40 PM
Misbehavin's Avatar
Misbehavin
There's no adjustment. If you have a leak, there is a hole or spot the water is getting through. With that year model, look closely on the section that holds the rear glass. It's separate from the rest of the top, and will often end up with a hole right below the rear glass corner.
If that doesn't provide you with the source of the leak, try using a water hose to pinpoint the problem.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
