Sponsored by:
Sponsored by:
Foxbody 1/4 Windows
Old 07-05-2010, 10:58 PM
Shaft
Shaft's Avatar
Default Foxbody 1/4 Windows
My 1/4 windows do not roll up or down, but I can hear the motors turning. I see a lot of foxbody's with the top down and the 1/4 windows up so I am sure this is a common problem. What parts generally wear out on those, or are they just off track? I'd like to know before I tear the thing down.
Shaft is offline
Old 07-15-2010, 01:18 PM
Turbo4banger
Turbo4banger's Avatar
TTT... im bumping up the thread because I too have the exact same problem as SHAFT... any insight would be helpful, I don't like putting the top down and not the rear 1/4 windows..
Thanks,
Turbo4banger is offline
Old 07-15-2010, 09:39 PM
Shaft
Shaft's Avatar
Since there isn't a whole lot out there on these windows, I'll document the progress of the repair.
Chris, where in Texas are you at? I live in Baytown.
Shaft is offline
Old 07-16-2010, 09:26 AM
Turbo4banger
Good luck with repair, and I'll need the insight, I am going to tackle that after I replace the top.
I am Katy/Houston area, not far from you.
Have you visited www.westsidemustangs.com there are few Baytown member on there... Its a local club
Old 07-16-2010, 08:51 PM
Shaft
Shaft's Avatar
Awesome. After I do mine then we can probably get together and do yours. I also need to do the top on mine.
Shaft is offline
Old 07-19-2010, 12:48 AM
Turbo4banger
I went a head and pulled the drivers side 1/4 motor... it works without pressure/tension on the gear, but as soon as I attach to window gear it wont spin. I spoke to a buddy of mine, he says it common and I can get a gear kit for the motor real cheap, I will let you know if I can find it. But a few friends of mine came over and installed my new top... WOW, it was interesting and fun, took 7 hours but learned a lot.
Old 07-19-2010, 02:49 PM
PNYXPRESS
PNYXPRESS's Avatar
I have the same issue with my d/s door window. I can hear the motor working but the window wont move, I can, however, manually move it by push down or pulling up on the glass. Let me know what you replace if you can fix it, please.
PNYXPRESS is offline
Old 08-04-2010, 09:26 PM
Little Chicago
Little Chicago's Avatar
I just bought a 93 LX & took the quarter windows out. Now cant get them back in LoL! Does anyome have a diagram of the components? The dumbass I had helping me took both them out & now we have nothing to go by reinstalling. The motor on LH was bad on mine, plus they didnt go all the way to the conv top.
Little Chicago is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
DreadPirateRoberts
09-26-2015 02:11 PM
heslekrants
09-23-2015 04:02 PM
Quick Reply: Foxbody 1/4 Windows
