vert top has a small slice
Old Jul 30, 2010 | 10:31 AM
stang1012's Avatar
stang1012
Default vert top has a small slice
I just noticed my top has a small tear, about 1/4 inch. What do you guys use to patch it up??
Old Aug 2, 2010 | 08:41 AM
scan1959's Avatar
scan1959
Stang,
In my vert installation shop, the repair goes like this: Get a tube of "Amazing Goop" by Eclectic Products, Inc. This company sells a cross between super glue and silicone sealant. It dries faster and clear. I like the one(they sell 3 or 4 different kinds, ie Automotive, Household, etc.) called "Plumbing" Goop.
Get a small piece(1 1/2" square) of vinyl or canvas type material. Apply the Goop onto the vinyl or canvas and apply it to the backside(underside or toward the interior) of the car. Walk away from it for 3 to 5 minutes. Now go back to the patch and hold a small board over the patch from the inside of the car and press upward and outward while pressing down into the patch from the outside of the car.
This lets you work the convertible topping into the patch and smear the adhesive around into the topping while keeping something to press into. If you push into the topping without some kind of backing, you won' get as good of a smear because the topping will flex too much.
Afterward, I dribble some into the actual tear/rip on the top side, but just enough to fill in the void and hopefully stop it from tearing too much in the future.
The idea is to stabilize the rip from the backside and then fill the topside without making a unsightly "bandaide" type patch to be seen on the outside.
Old Aug 10, 2010 | 12:07 PM
stang1012's Avatar
stang1012
thanks...the only thing is I cant get under the tear (from the inside)
Old Aug 14, 2010 | 06:15 AM
scan1959's Avatar
scan1959
I guess then, that I would still recommend this adhesive and only use it for the topside of the rip/tear.
How old is the top?
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
daltron
Apr 28, 2016 08:10 PM
Bokeo
Oct 10, 2015 08:28 PM
UrS4
Sep 30, 2015 10:13 AM
