water spotted windows
Old Feb 6, 2008 | 05:24 PM
benz5800's Avatar
benz5800
Default water spotted windows
my rear quarter windows seem to have water spota on them and no matter how hard i scrub they wont budge. therfore i need some of you fellers to tell me some tricks that are worth trying
Old Feb 6, 2008 | 05:50 PM
MelloYello's Avatar
MelloYello
Default RE: water spotted windows
Try using steel wool
Old Feb 6, 2008 | 08:32 PM
SVTBill's Avatar
SVTBill
ORIGINAL: MelloYello
you have to be very careful with steel wool because it can def. scratch your windows up pretty bad
to the OP, if you're going to use steel wool def. use it as a last resort. i would start out with some vinegar/water mix...50/50. if that doesn't work you can step up to a light chemical polish and work that in. if that doesn't work you can step up once more to an abrasive polish, by now the spots should be gone, and if they're not then they're really etched in there. finally you may have to use some steel wool. only use 0000 grade, anything more will def. harm the glass
after you're done with everything be sure to put a good wax or sealant on top of the glass to prevent from future spotting
Old Feb 7, 2008 | 11:37 AM
MelloYello's Avatar
MelloYello
You do everything the long tedious way SVT Bill!!! lol
If you use Double 00 steel wool you wont scratch it!
Promise
Old Feb 7, 2008 | 02:51 PM
DuFFMaNN's Avatar
DuFFMaNN
MELLOW IS LYING!!!!!!!!!!!!!!
[8D][8D][8D][8D]
Old Feb 7, 2008 | 03:37 PM
MelloYello's Avatar
MelloYello
How am I lying? WTF
Old Feb 7, 2008 | 03:50 PM
DuFFMaNN's Avatar
DuFFMaNN
Im just mesisng with you!
Old Feb 7, 2008 | 09:41 PM
MelloYello's Avatar
MelloYello
ok I dont mind messin
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
