cracked windshield is spreading
Old Oct 7, 2010 | 06:21 PM
usmcmp90's Avatar
usmcmp90
Default cracked windshield is spreading
so i got a cracked window back in mid september and it was fine and wasn't spreading untill yesterday when it started to get cold and i guess that factored in with using my windshield defroster started to spread the crack. so does any1 know of any solution to just keep or atleast slow down the spreading????
Old Oct 7, 2010 | 07:31 PM
DRAGUL's Avatar
DRAGUL
Only solve for your problem is to replace the windsheild. There is no way that I know of to stop it. Also you can get pulled over and ticketed for it. The winsheild is also part of the body. It strengthens it and is designed to fail in a certain way along with the body in a collision. You need to replace it.
Old Oct 7, 2010 | 08:19 PM
MustangFirstCar's Avatar
MustangFirstCar
Yes, there is really no way to fix it. You just have to roll over and get a new one.
Old Oct 17, 2010 | 09:01 PM
xenocide's Avatar
xenocide
Yeah, like other's said, you are going to have to replace it. Depending on your state, full coverage insurance will cover 1 per year. This is the case here in FL.
Old Oct 17, 2010 | 09:28 PM
bigtom's Avatar
bigtom
This is what I do for a living. This guy is exactly right. Make sure you use a reputable company in your area. I see a couple of horrors a week where windsheild were replaced by lazy incompetant idiots. When the glass is replaced make sure they follow NAGs (national auto glass) standards and cut back the original urethane and primer both the glass and body. If you can find a shop that complys with AGRSS (auto glass replacement safety standard council) then you should be good because they only certify shops that follow very stringent standards and therefore weed out the idiots that don't care about your safety and do ****ty work.
All the best
jma2
Jul 10, 2023 01:00 AM
Vrooom
Feb 21, 2016 05:25 PM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
wraith777
Sep 28, 2015 10:49 AM
bconboy
Sep 24, 2015 01:55 PM
