Help Radio replacement stock 1997 4.6 Dolby mach & a/c bezel removal
Old Jun 18, 2022 | 06:27 PM
199746mustang's Avatar
199746mustang
Default Help Radio replacement stock 1997 4.6 Dolby mach & a/c bezel removal
age 22 first car 97 4.6 automatic Dolby radio with mach
both radios dont come out with radio ford tool
plastic a/c bezel wont come out either feels bolted
I am having trouble navigating how to remove the stock radio. The top one radio I have tried so many times is to use the metal radio brackets that insert into the radio to compress the springs; which make the radio slide out. But after 30 attempts it literally feels like there's something more behind being blocked so it won't slide out. Making me think I need remove the bezel that blocks the whole radio unit from coming out.
So I assume that the plastic bezel for the a/c radio plastic needs to be removed first. I've removed the two nugs underneath near the shifter. But I've seen two types of videos; one where people are simply able to just pull off the a/c bezel without needing to do anything but remove the two nugs, and the other where there are also two deep screws behind each radio that need to come out before removing the plastic a/c bezel. I think my car has the two screws behind the unit because after removing the shifter plastic, I tried pulling the botting part of the a/c plastic off towards me, and it felt so strong as if it was screwed down in the middle near the radios (a/c bezel no budge)
If anyone has any knowledge on this a/c plastic bezel or factory radio removal of the 1997 mustangs please feel free to put down what you know, it would be greatly appreciated since I am planning on restoring this car throughout my life.
and both radios literally wont budge with the metal brackets inside, the plastic ac bezel also wont move anywhere along the middle
anyone who replies is a life saver thank you for what you have to offer
199746mustang
Jun 18, 2022 06:28 PM
mister_aj
Dec 12, 2011 11:30 PM
Obsequious1
Oct 10, 2008 12:32 AM
Red02GT
Mar 5, 2007 12:07 PM
dsmart5
Mar 14, 2006 06:10 PM
