AIR/FUEL RATIO GAUGE-AUTOMETER
Old Mar 2, 2006 | 01:53 AM
sfi's Avatar
sfi
Default AIR/FUEL RATIO GAUGE-AUTOMETER
hAS ANYONE PUT IN A AIR/FUEL RATIO GAUGE FROM AUTO METERPART 6175. i HAVE A 2002 GT AND THE DIRECTIONS TELL ME NOT TO HOOK IT TO THE O2 SENSOR UNDER THER CAR.
wHERE DO i HOOK IT AS WELL AS THE REST OF THE WIRES. iM NOVICE AT THIS. Help.
Old Mar 2, 2006 | 01:55 AM
SpecterGT260's Avatar
SpecterGT260
Default RE: AIR/FUEL RATIO GAUGE-AUTOMETER
ORIGINAL: sfi
I just got mine in the mail. i think ur sposed to hook it up to the wire going from the DCM to the 02 sensor. Not quite sure where the DCM is tho....
Old Mar 2, 2006 | 02:01 AM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: sfi
Caps lock, PLEASE.
Autometer sells an O2 sensor you are supposed to use with the gauge I believe. I remember reading they want you to drill it in at the H or X in your exhaust. That's just what I remember, don't count on it. You would be best e-mailing autometer about it... then coming back here and putting what answer you got in so if someone searches and finds this the answer will be here.
Old Mar 2, 2006 | 02:07 AM
SpecterGT260
http://www.autometer.com/cat_gaugede...gid=2567&sid=4
http://www.autopartswarehouse.com/ap...Autometer+2244
pretty sure im not droppin 100 bucks on that thing. It should work with standard ford 02 sensors. If they are fouled at all just get new ones at autozone. They are pretty cheap I think.
Old Mar 2, 2006 | 02:21 AM
sfi's Avatar
sfi
Ill shoot autometer a email and see what they say. thanks. I believe in my instructions they said not to splice into the o2 sensor itself. they said something about splicing into the Powertrain control module(PCM) for the o2 sensor If you find anymore info. it would be appreciated.
Old Mar 2, 2006 | 02:24 AM
SpecterGT260
ORIGINAL: sfi
thats what I meant.... I was thinking drivetrain instead of powertrain... my bad [:@]
Old Mar 3, 2006 | 12:30 AM
sfi's Avatar
sfi
I EMAILED AUTO METER AND IM JUST WAITING FOR RESPONSE. I seen plenty of pics with people with a/f meters, I can't believe Im not getting more resonses. Am I posting in the wrong section ???
Old Mar 3, 2006 | 01:18 AM
Tac2cul's Avatar
Tac2cul
The signal wire from the gauge goes to either pin 60 left O2(GREY/LT BLU) or 87 right O2(Red/Black)on the PCM
Which is located in the passenger kick panel.
or if u wanted to use the O2 sensor
The wires on the 02 sensor are:
GREY/LT BLU signal Right front O2
Red/Black signal Left front O2
This wiring color code and what not is for a 2002
now where did my PCM pin layout go?
hehehehe damn cant find it...found it
i believe dats it..... give it a try and see if it works either way
Jb145700
Aug 21, 2022 06:37 AM
articman
Jun 21, 2018 11:45 PM
uberstang1
Sep 20, 2015 06:42 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Sep 3, 2015 07:14 PM
