Tire Pressure
Old Mar 2, 2006 | 07:26 PM
SXGT's Avatar
SXGT
Default Tire Pressure
my tires say 44psi max and iam going to be having a PACKED trunk and back seat and passenger for a a 800 mile trip. I would guess i have an extra 300- 400 lbs more then normal. right now my tire pressure is about 32-35psi is this ok? or should i run it at the full 44psi.
Old Mar 2, 2006 | 07:38 PM
Tim37's Avatar
Tim37
Default RE: Tire Pressure
if you max them out the ride is going to suck. but you will get better gas millage.
Old Mar 2, 2006 | 08:13 PM
hot wheels's Avatar
hot wheels
i always run run my tires 2lbs less than max. better feel of the road and tire reports don't ever really say anything bad about max pressure just under inflated. and yes better gas mileage
Old Mar 2, 2006 | 09:43 PM
03YellowPony's Avatar
03YellowPony
You should ALWAYS have the tire pressure set to the vehicle's settings. It's either on the door jam, or in your manual.
Old Mar 2, 2006 | 10:10 PM
mustangman02232's Avatar
mustangman02232
ORIGINAL: 03YellowPony
and its better to be a few pounds over then under.
Old Mar 2, 2006 | 10:13 PM
hot wheels's Avatar
hot wheels
look at a high performance tire at 32lbs and then at 44lbs then tell me which pressure looks better? 32lbs feels like your riding around on mush let alone in looks like its flat.
Old Mar 3, 2006 | 12:09 AM
ikeybmg's Avatar
ikeybmg
just put about 40psi in em. lol...meet in the moddle.
Old Mar 3, 2006 | 04:03 AM
Stang9946's Avatar
Stang9946
I checked my front tires yesterday because they looked really low..they had 20lbs in them. I was so embarassed.[:@]
Old Mar 3, 2006 | 05:34 AM
hot wheels's Avatar
hot wheels
dude like i said when you put $1212 on your stang then and only then let someone else tell you how much pressure to pu in them. $302 tires and you won't listen to me FINE listen to your door jam [sm=bangbang.gif]
Old Mar 3, 2006 | 11:39 AM
gt96stang's Avatar
gt96stang
ok, my sidewall says 44 as well, but I keep them at 35 and it is wearing the tread perfectly across the whole tire.. I personally wouldn't put the MAX because when you are driving, the air heats up, and expands, thus putting more pressure in the tires, which would put you past the max recommend by the tire..
Just my .02
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
marc954
Sep 29, 2015 11:18 AM
