multi-function switch replacement help
Old Mar 16, 2006 | 10:50 PM
bobfromaccounting's Avatar
bobfromaccounting
Default multi-function switch replacement help
Hi,
I am trying to replace the multi-function switch on a 98 mustang. I unscrewed the adjustment lever for the steering wheel, removed the 3 screws to the steering wheel shaft cover, but I cannot get the top or bottom pieces removed. I can't get the top past the plastic on the ignition switch and the bottom cover is stuck on the lower dash cover. How do I remove the plastic ignition switch cover (or do I need to) or do I remove the lower dash cover? I removed the two bolts on the bottom of the dash cover, but it appears to be attached at the top. Didn't want to force it too much and break it. Any help would be appreciated.
Thanks,
Bob
Old Mar 16, 2006 | 10:51 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: multi-function switch replacement help
If the trim cover goes completely around the ign. switch, you will have to remove it to get the cover off.
2007CalSpec
Dec 13, 2020 11:42 AM
5.0muscle
Jan 11, 2016 01:17 PM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Art161
Sep 9, 2015 10:33 AM
