short tube vs long tube
RE: short tube vs long tube
I was told that Long Tubes are better, but should only be used if you have or plan to do a lot of modding to your engine. If you engine is going to stay mostly stock then go for the short tube headers.
The Shortys give a supposed 5-6rwhp from what I have read and long tubes are way better which puts mid lengths in between. I would assume the long tubes sound pretty mean too. I know very little about headers and have not bought any yet either =(
tatoos' right, long tubes are probably better for a hotter motor, there used when more flow is needed (big heads,cam,intake). shortys are good too, in general they probably give you better low end power and long tubes will help generate power for high horsepowered, high reving cars.
