Urgent...kinda: reverse lights
Old Mar 29, 2006 | 11:49 PM
jtstudley's Avatar
jtstudley
Default Urgent...kinda: reverse lights
Hey, I'm new here and I just bought my first Mustang in January. Its just a 2001 V6 with little mileage. Anyhoo, my friend noticed that my reverse lights would go on even out of reverse every once and a while. It was only happening once and a while at first and I just blamed it on the new stereo that i just put in. Now they are on all the time and I've gotten pulled over and told to fix it or next time its a ticket. Luckily its been by a different cop each time. So a mechanic said there's a switch that can get stuck somewhere the transmission rubber beffer thing. I took it way apart and am to the point where I can see the ground. I was just wondering if anyone knew where that switch is and could tell me before I put the stick back on or before I get a ticket. Thanks. sorry about the long post
Old Mar 30, 2006 | 12:24 AM
waxyourboard's Avatar
waxyourboard
Default RE: Urgent...kinda: reverse lights
Hm, can't help you there, but you could always just unplug the lights (not very safe for backing up, but you won't get any tickets)
Old Mar 30, 2006 | 12:52 AM
dan's Avatar
dan
what kind of transmission?
Old Mar 30, 2006 | 09:52 PM
jtstudley's Avatar
jtstudley
manual
i took the reverse bulbs out but i would prefer to fix the problem
Old Mar 30, 2006 | 10:09 PM
83beast's Avatar
83beast
sounds like maybe a loose or shorted wire. check the side of the tranny. theres usually a small plug/clipped wire thats real small. check to see if it is the rear lights and if it is, could be corroded/loose/ or shorting. just a guess.
Old Mar 31, 2006 | 03:06 AM
jtstudley's Avatar
jtstudley
thanks
im startin to think the the "switch" is in the gear box or another metal enclosed box so i might not be able to fix it. But if the wire shorted, wouldn't the reverse lights never be on instead of always on. I really dont want to have to take it to a mechanic but i heard electrical problems can be expensive. Does any one think they know the ballpark price on getting this fixed would be around? If its to much im gonna roll w/o them till i get my CAI (K&N unless you all have better suggestions) and upgrade my speaker system and get my PA system hooked up.
Old Mar 31, 2006 | 03:39 AM
QuickShortBus's Avatar
QuickShortBus
I ♥ Acer
It's not in the transmission, per se. It is screwed into the side and can be changed very easily.
Old Mar 31, 2006 | 04:16 AM
jtstudley's Avatar
jtstudley
the wire or the switch?
Old Mar 31, 2006 | 10:03 AM
83beast's Avatar
83beast
if a wire is shorted, it could be that the coating is rubbed through and is bouncing around and touching metal at random times. and the switch is in the trans and the wire is "clipped" to the side of the tranny. pull it off and clean the terminals. on the wire end and the trans end. that cant do any harm and might be it. it was the prob on my 83 T5.
Old Mar 31, 2006 | 09:14 PM
jtstudley's Avatar
jtstudley
i called a mech and he said that it is a switch that plugs into the tranny. Do you know where the wire that you were talking about, beast, is cause i dont want to drop $100 bucks of my CAI fund into this
thanks
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
