Octane Booster
Old Mar 30, 2006 | 08:42 AM
CrimeScene's Avatar
CrimeScene
Default Octane Booster
I know there is a big debate on this one so lets play nice pls.
Was wondering if anyone uses any kind of booster and seeing results? Not talking about some off the wall stuff but what you can get at Auto Zone or Pep boys type of auto store.
I know there are tons of sites that did some kind of testing in one form or another but everyone has diffrent results it seems.
CrimeScene
Old Mar 30, 2006 | 09:19 AM
GreyStang's Avatar
GreyStang
Default RE: Octane Booster
For a stock engine, you don't need it..
Old Mar 30, 2006 | 10:18 AM
MustangChris04's Avatar
MustangChris04
steeda sells this chemecal x booster. I dont know if it really works...
Old Mar 30, 2006 | 11:48 AM
alexr's Avatar
alexr
waste of money.
Old Mar 30, 2006 | 01:24 PM
motormike's Avatar
motormike
are you talking about this?
https://mustangforums.com/m_662753/tm.htm
Old Mar 30, 2006 | 02:38 PM
ByPopularDemand's Avatar
ByPopularDemand
Dont bother
Old Mar 30, 2006 | 04:32 PM
projectstanger's Avatar
projectstanger
Octane boosters will only increase the amount of octane points in your gas. Having a higher octane gas will not increas horsepower, increase fuel mileage nor make your engine run cleaner. You will only need to use octane boosters if you're engine is modified enough to increase the compression in the engine. For a stock engine, use the fuel grade specified in your manual.
The only thing that you will be increasing with octane boosters on your engine at the moment will be your expenses!
Old Mar 30, 2006 | 06:10 PM
TBird232ci's Avatar
TBird232ci
Most octane boosters will NOT increase octane in your gas. If it does, its so minor that it doesnt make a difference. Most boosters will raise you .2 points of octane in a full tank, where as you see the names saying "114" or whatever.
There is a product called Torco i believe that *does* work, but its just a bandaid.
Octane in most N/A or stock compression engines makes no difference. I run 93 octane only because i run 21psi of boost in my car, and even then, i get the occasional spark knock.
Old Mar 30, 2006 | 09:49 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
We have been over this before. Octane boosters are not worth the money.
uberstang1
Sep 21, 2015 09:04 AM
Big Al's 03
Sep 15, 2015 09:05 AM
MasterLanMan
Sep 13, 2015 08:21 PM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
