Thoughts on Used control Arms
look at the bushings. they shouldn't be cracked or broken, other than that I dunno how to tell if the bushings are still good. also check the zirc/zerk/zirk(??)/grease fittings and see if they are all clogged up or anything else.
you might want to find out how much replacement bushing will cost before you make a decision, just in case.
I'd tell you to look at the welds and make sure they are good and solid, but I got some BBK's, and the welds on them look like a gorilla got ahold of the machine for a couple of minutes and just absolutely went ape****
Yup...what they said. Check the bushings to see if they are dry and cracked or crushed. They will most likely be fine if they were greased properly. If not, bushings aren't too expensive.
Good luck.
Good luck.
Ebay auction, he said he would end it early for me if I brought him cash, what do you guys think is a fair price for these?
Control Arms
Control Arms
Sep 25, 2015 09:06 AM
