Dome light
Old Apr 9, 2006 | 11:02 AM
Dirtysouthstang's Avatar
Dirtysouthstang
Default Dome light
i have a 99 V6, was driving home from work last night and my dome light would not turn off. i turned the switch for the head lights, and nothing happend when i got home. it stayed on for a good 45 minutes
Old Apr 9, 2006 | 12:11 PM
antiv6's Avatar
antiv6
Default RE: Dome light
take out the bulb
Old Apr 9, 2006 | 12:17 PM
mustangman02232's Avatar
mustangman02232
not exactly sure on this, but do the coupes have the map lights on the side? maybe you fliped one of those on?
Old Apr 9, 2006 | 02:17 PM
antiv6's Avatar
antiv6
many people have had problems with the dome light staying on, most of them just take out the dome light bulb, I think a sensor or something is messed up, this issue has been brought up many times, i dont like telling people to search but it might help you out
Old Apr 9, 2006 | 09:59 PM
I_AV8_4U's Avatar
I_AV8_4U
I actually have the answer to this troubling issue.
FORDs have a real problem with their door switches. Many FORD's dome lights stay on for no apparent reason...but if you simply spray WD-40 on both door switches and cycle them many dozen times quickly, this should cure the problem. If not, you can find a used switch (or spend the cash for a new one) and try that.
Typically a problem on the Taur(i?) and the Explor/Exped/Excurs...first I have heard of this on a stang, but hey!!!
Good luck.
Troy
Old Apr 10, 2006 | 12:34 AM
gt96stang's Avatar
gt96stang
ORIGINAL: I_AV8_4U
Good luck.
Troy
Yes, this will fix your problem.... I had a 97 SHO that had that problem with the lights staying on.. A couple shots of the good ol WD-40 on all the door latches and never ran into the problem again.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
