gauge compliment
Old Apr 16, 2006 | 09:46 AM
groundpounder's Avatar
groundpounder
Sith Lord/Site Mod
Default gauge compliment
I have a naturally aspirated, non-nitrous injected 306. I currently have a water temp, oil pressure and A/F gauge to install and I have a couple of questions:
What does everyone else run gauge-wise on N/A engines? I'm thinking about an oil temp gauge, but eh, you know.
Also, where did you all splice in for power to your lights for the gauges? Thanks, boys and girls!
Old Apr 16, 2006 | 10:52 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: gauge compliment
I run, fuel pressure, boost, temp, o/p, volts and a/f. I tapped the light for the hvac panel.
Old Apr 16, 2006 | 12:41 PM
groundpounder
Sith Lord/Site Mod
Pro, I was hoping you or Ang would chime in. Thanks. I'm beginning to thinks there are a buncha knuckelheads on this board that have never built anythang but like to post in tech and say "good idea" "sounds about right" or " ^^+1". You guys are the truth!
I figure I'll be making 325-350 HP since I have an E303 and edelbrock vic jr's, 1.6 rollers, port matched SVO intake, yada yada yada, so I'm wondering what information I'll actually need in the cockpit versus having a bunch of cool gauges for show.
Obviously, I won't need to monitor boost since I'm not forcibly inducted, and it seems to me that fuel pressure is not quite as critical to monitor on a N/A car vs boost or nitrous. I think if I were to add a gauge to the three I have now (o/p, H20 temp and A/F), it would probably be fuel pressure or oil temp. I trust my factory volt meter, so I won't be redundant there I think.
Any suggestions? I'm leaning towards being good with the three gauge setup I have now, but if someone were to chime in and say, "you DEFINITELY need a [insert gauge name here]" I'd consider it.
Pro, can you elaborate on that light hookup a little? I'm not quite reading you there.
Old Apr 16, 2006 | 01:01 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
AutoMeter Sport comp:
Volt
Water temp
Oil pressure
Fuel pressue
AutoMeter Ultimate:
Tach
N/A 306
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
BeatnikFink
Oct 1, 2015 08:00 PM
mungodrums
Sep 28, 2015 10:54 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
