Digital Gas Meter?
Old Apr 20, 2006 | 12:17 PM
Chopper's Avatar
Chopper
Default RE: Digital Gas Meter?
ORIGINAL: ARdoller
ORIGINAL: M1ke
if you have a 96-98 you can get this puppy. i know i plan to
http://www.nordskogperformance.net/p...301-dp5304.htm
its a full replacement LED gauge panel
this is straight from their site
Easy Installation.
Full LED Lighting.
0-100 PSI oil pressure gauge with sender reads in 1 lb. increment for precise readings.
50-350 degree water temperature gauge and sender.
8-18 volt voltmeter with low and high volts warning.
0-99% fuel level gauge works with existing factory ohm fuel level sender.
300 mph digital speedometer with LED bar graph, odometer with trip.
Recalls highest speed, 1/4 mile ET and 0-60 time.
Easy one button calibration for various axle ratios and tire sizes.
Can be used with existing electronic cruise control senders or use S9013 if your vehicle is not equipped with a functional cruise control sender.
0-9900 rpm digital tachometer in 100 rpm increments with LED bar graph.
Microprocessor controlled for accuracy and dependability.
Blacks out completely when powered off
as nice as it would be to have digital gas/oil/temp readings, that has got to be the stupidest thing ever. when youre driving, you cant just glance at the speedo/tach and know where youre at like on a radial analog cluster... and its definitly not anything you would want if you shift (yourself) at high rpms, because you wont know when youre reaching redline because the digital numers will be rapidly changing so fast you wont be able to read it clearly.
The best and SAFEST way to know when to shift is to have a shift light.I have a Raptor and it works great.
Old Apr 20, 2006 | 02:49 PM
impulseballer's Avatar
impulseballer
ok the test gauge thing worked for me...i wish i could keep the fuel thing on all the time.
Old Apr 20, 2006 | 07:11 PM
MustangChris04's Avatar
MustangChris04
doesnt work on 04's?
Old Apr 21, 2006 | 04:10 AM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: XbcSharpShooter
I have an 04, I said earlier it works fine for me. If you have the digital odometer, it will work for you.
It would be nice to keep it on fuel, or temperature at all times (its temperature reading is realtime, I've found when I go WOT on the highway, getting it up near redline, it'll raise a few degrees, and once I get off it, it'll come back down... same with sitting idling, temerature will rise to a bit over 100 then the fans for the radiator will kick on and the temperature will drop back down to normal... all this time the actual temperature needle doesn't move), but you need to hold the reset button every time you turn it on, gets annoying after a few startups.
Old Apr 22, 2006 | 03:07 AM
Rook6's Avatar
Rook6
Hmm... I wonder how well that home-made CAI would work...off to Home Depot!
Old Apr 23, 2006 | 06:42 PM
impulseballer
lil off topic no?
Old Apr 23, 2006 | 07:04 PM
Rook6's Avatar
Rook6
In an above reply there is a link to a site on which, besides directions on utilizing the preprogrammed digital readouts, it is explained how one can build a home-made CAI using materials found commonly at Home Depot. Hence my side comment. Not quite "off" topic....I'd say "just a bit outside"
Old Apr 23, 2006 | 10:11 PM
impulseballer
roger that
4cylinderplus2
Oct 9, 2020 07:45 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
