17" Billitt Wheel ?
Old Apr 19, 2006 | 09:44 PM
Freedogg's Avatar
Freedogg
Default 17" Billitt Wheel ?
I have a 1988 mustang gt. I want to put the 17" billitt wheels on. I plan on buying the 4 to 5 lug 2inch adapter. I know its not the best but I dont drive hard just cruise around. My question with that setup how big of tires (wide) could I put in. I want to put 17X10.5 deep dish if I can. It has a 6.8 backspacing. What tire could I get to fit on the rim and go in the car without any mods? Thank you in advance
Old Apr 19, 2006 | 09:58 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: 17" Billitt Wheel ?
Do you mean Bullet wheel. Anyway, you won't get a 10.5 on the back of a fox w/o some major work and even then it will be sketchy.
Biggest 17" wheel and tire combo w/o mods is 17x9 6.0 b/s, w/ 275/40/17 tire.
Old Apr 19, 2006 | 10:09 PM
Freedogg's Avatar
Freedogg
yes your right its bullitt. So if I got the non deep dish that are 17X9 with a 5.95 they will fit my setup correct. Do you know this for sure or an educated guess? How far do you think they will hang out at least 2 inchs from the adapter any more do you think? Thnaks for your help
Old Apr 19, 2006 | 10:18 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: Freedogg
On a 5 lug they will fit perfectly cuz that's what I run. You don't wanna run spacers on that size. HJust won't look/fit right. Do it right and do the conversion. It will be worth it in the long run. Or stick w/ the 4 lug choices.
They sit in the fenderwells and don't rub. 275/40/17
Old Apr 19, 2006 | 10:27 PM
Freedogg's Avatar
Freedogg
How hard is the conversion. It just looks like new front rotors and new rear axels. How many hours do you think it would take to put it? You are right it would look kind of dumb hanging out 2 inchs extra. So thats what you have on yours, looks very nice.
Old Apr 19, 2006 | 10:37 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: Freedogg
Thanks,
The conversion depends on alotta things. Which type you go with, how much you wanna spend, where you get the parts. Here is are some links that might help you in your quest for the 5 lug wheel LOL!
http://www.stangnet.com/tech/lug.html
https://mustangforums.com/m_968156/tm.htm
Old Apr 19, 2006 | 10:38 PM
Freedogg's Avatar
Freedogg
Thanks a ton, I will look them over and will do it the right way. Tory
Old Apr 19, 2006 | 10:40 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: Freedogg
NP! Good luck
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
