compression check?
Old Apr 24, 2006 | 06:50 PM
p0rsche23's Avatar
p0rsche23
Default compression check?
how could i do a compression check on my 94 pontiac sunbird with a 2.0l 4 cylinder....besides sticking my finger in each hole while starting it....lol
and if it does have low compression,what could be the cause of it and could it be fixed or would sending the motor back be the easiest solution?
Old Apr 24, 2006 | 06:55 PM
Tac2cul's Avatar
Tac2cul
Default RE: compression check?
you could borrow a compression checker from autozone or a buddy and check it that way
if its low it could be the head gasket leaking/the rings/cracked head
it can be fixed but you would have to tear it down to finger it out
unless you can give us some simptums your experiencing
im guessing its not running?
Old Apr 24, 2006 | 07:35 PM
p0rsche23's Avatar
p0rsche23
yeah we just put a motor in it and it just cranks and cranks but wont start.....we did this thing where we put a little oil in the plug holes to make the rings seal up or something like that....and then when i tried to start it it acted like it wanted to start(like it kickedup alittle)but then like a second later it went back to the same way it was sounding.,,,and kept going thatway.....the nearest autozone or auto shop is like 30 miles away but im not sure if its gonna be the compresion or not.....
the timing was right,it had a spark,but not That good of one but still shouldnt be the problem...and its getting fuel....and it had alittle compression but this mechanic friend who works at the chevy place said it wasnt enough and thats why we put the oil and tried that......if u got any other tips or things i could see to help diagnose it,it would help alot
thanks
Old Apr 24, 2006 | 07:50 PM
Tac2cul's Avatar
Tac2cul
usually u would stick oil in after a compression check if u got low numbers to see if the rings were bad (least if i remember correctly anyways been awhile) As your buddy says to temp fix the compression issue.....
u will need a compresion check 4 sure to rule it out....
Old Apr 24, 2006 | 08:12 PM
p0rsche23's Avatar
p0rsche23
yeah him and his dad are coming over after they get off if he can find a compression checker......im gonna guess a head gasket damnit but i hope its something simpler to fix becuz we have a warranty on this motor but i dont wanna take it back out only to get a better one to put right back in [:@]....fkin sucks i need this car to get back to work since my stang is halfway wrecked
Old Apr 24, 2006 | 08:27 PM
Tac2cul's Avatar
Tac2cul
what do the plugs look like?
Old Apr 24, 2006 | 08:40 PM
p0rsche23's Avatar
p0rsche23
what do u mean,they look good,just not real good spark cming from them
Old Apr 24, 2006 | 08:58 PM
Tac2cul's Avatar
Tac2cul
what color are the tips?
Old Apr 24, 2006 | 08:59 PM
p0rsche23's Avatar
p0rsche23
like bronze looking.
Old Apr 24, 2006 | 09:04 PM
Tac2cul's Avatar
Tac2cul
pick one of these
http://www.4x4review.com/quads/tech/SparkPlugs.asp
the first one is kinda what u are describing ocrrect?
If so all seems well then
if they are the same plugs that came with the motor...if not do u have the old plugs layin round?
