Rear end gear
Old Apr 26, 2006 | 02:52 PM
stangfreak302's Avatar
stangfreak302
Default Rear end gear
Hey got two quick questions I am building a 91 thunderbird 5.0 right now. I am putting an eaton m90 on it and was wondering what I should put in it for injectors. (how big) Also the car has the independent rear suspension and I think it is just a 8.8 and i was wondering if anyone knew if I could just put an 8.8 ring and pinion out of a mustang in it?
Old Apr 26, 2006 | 10:29 PM
turt's Avatar
turt
Default RE: Rear end gear
It has independant rear suspension??????? Huh?? [&:]
Old Apr 26, 2006 | 10:32 PM
Fast96's Avatar
Fast96
The ring and pinion are the same. If you get used gears they need to be setup by someone that knows how to pattern them well. It's difficult with used gears b/c they already have a wear pattern.
Old Apr 27, 2006 | 04:16 PM
stangfreak302
Thanks for all your help about the gears now if anyone know about injectors. I was planning on running 30 lb injectors I think that should do the trick.
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 1, 2015 08:16 PM
inyadreems
Aug 21, 2015 09:10 AM
