Temp Gauge Fluctuates
Old Mar 29, 2004 | 04:53 AM
tj_gavin's Avatar
tj_gavin
Default Temp Gauge Fluctuates
I have a '94 3.8L and my temperature gauge is fluctuating between 1/2 and 3/4, mainly when I'm idling. If I'm doing any kind of steading driving though, i.e. freeway or highway, it's stays pretty constant at 1/2. I'm used to having my temp gauge never fluctuate. Could it just be a bad thermostat?
Old Mar 29, 2004 | 11:55 AM
Art92GT's Avatar
Art92GT
Default RE: Temp Gauge Fluctuates
could be low on coolant. just a guess, if you haven't checked it already.
Old Mar 29, 2004 | 05:36 PM
vfast's Avatar
vfast
I ♥ Acer
every mustang should have mechancial gauges..I suggest buy a nice set..those electric ones are terrible
Old Mar 29, 2004 | 05:46 PM
MelloYello's Avatar
MelloYello
check coolant and your thermostat.....
Old Mar 30, 2004 | 10:41 PM
vfast's Avatar
vfast
I ♥ Acer
several things...a new stat maybe in order..when was the last time the rad was flushed?....napa make some good ****. it's a powder
Old Mar 31, 2004 | 05:53 AM
e40water's Avatar
e40water
Hey man Ive got the same troulbe too Ive 83 3.8L V6 stang I could be at the Mc D's driv thru and it could temp could hit 3/4 hot, But I know my gauges are shot though, Ive got a new rad / New therostat / Alot could be is the coolant could not be mixed properly, That plays a big role, I would first open youre rad cap check youre coolant level, Then run youre car with the rad cap off at idle let it warm up too see if youre coolant is moving through the cooling system, Most cases its youre thermostat and coolant mixture, Maybe you rad is plugged as well.
Old Mar 31, 2004 | 09:57 AM
WNDSOR's Avatar
WNDSOR
could be temp sender thats in your intake, might replace that. it sends the signal to the gauge as to how hot the coolant is. check your coolant level, sounds like the problem, my 93 f250 did that and it was low on coolant
Old Mar 31, 2004 | 09:25 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Vfast is right the stock gauges suck.
Get some mechanicals and then go from there.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
