Ignition and Distributor
Old Apr 2, 2004 | 03:07 PM
Obsol3te's Avatar
Obsol3te
Default Ignition and Distributor
I don't really know how to put this but well
what should I order for like well I want to redo my Ignition and junk
Like all the things that go along with it.
What am I going to be replacing?
Ignition of course, Distributor, Wires, and...?
Heres what will eventually be on my car (except for the headers need the rest of the exhaust for that first) whenever my intake decides to show up
ok
Current mods:
[ul][*] 4.10 Gears[*] Ford B Cam:
. 397-M-6250-B303 Duration': 224°/224° @ .050'
. Lift: .480'/.480'[*] 75 Dry Shot of N.O.S. Nitrous [*] Pro-M Bullet 75mm MAF for 24# Injectors[*] Chrome Breather Valve
[/ul]
Mods to come:
[ul] [*] Edelbrock Performer Intake(1500-6500)[*] 24# Injectors[*] Accufab 70mm TB[*] EGR Spacer[*] Steeda Aluminum Underdrive Pulleys[*] Bat. Relocation Kit[*] BBK 1 3/4" Ceramic Coated Long Tube Headers
[/ul]
I want to redo everything pretty much for around 400-500 hp
I hear MSD is a good brand, but what kind should I order?
And what else am I going to need besides wires,distributor,ignition?
I kinda want to order this for today along with a fenderwell CAI from bbk
Old Apr 3, 2004 | 02:28 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Default RE: Ignition and Distributor
Ignition module,Distributor,Coil,Wires,Plugs thats about it.
As for brands msd,petronix,jocobs i would stay away from accel they suck ***!
You have a summit book?Theres more than enough variety in there take your pick.
Old Apr 3, 2004 | 07:01 PM
vfast's Avatar
vfast
I ♥ Acer
maybe use a MSD dist....a jacobs coil and some low ohms wires with some autolite plugs...and a hotwire module for dwell saturation
Old Apr 4, 2004 | 12:10 AM
dghost22's Avatar
dghost22
MSD 6AL box PN 6420, MSD blaster 2 or 3 coil PN 8223, 9mm plug wires, Pro-Billet Ford 5.0L Distributor 1986 - 1993 PN 8456, and a decent set of plugs and you are there. If money is an issue you can go with a 6A box which does not have the rev limiter like the 6AL. Hope this helps....
Old Apr 4, 2004 | 12:11 AM
vfast's Avatar
vfast
I ♥ Acer
I use the holley wires only 25 ohms per foot
Old Apr 4, 2004 | 12:16 AM
dghost22's Avatar
dghost22
Hmmmm, I am not sure about the ohm reading on the MSD wires... wish i still had the box, lol.
Old Apr 4, 2004 | 03:35 AM
Obsol3te's Avatar
Obsol3te
ORIGINAL: dghost22
Yes that does help
Thank you so very much
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
dalehunter
Sep 25, 2015 10:51 AM
jaiidutch
Sep 14, 2015 10:29 AM
Wombatnation
Sep 13, 2015 09:16 PM
