New Springs
Old May 17, 2006 | 02:29 PM
DBovine's Avatar
DBovine
Default New Springs
I am looking at putting new Springs on my car, probably ford racing springs, and I was wondering if I need to change the stock shocks and struts?
Old May 19, 2006 | 11:23 AM
DBovine's Avatar
DBovine
Default RE: New Springs
No one has any input on this?
Old May 19, 2006 | 11:32 AM
91 5.0's Avatar
91 5.0
do you need to? no.
should you? yes.
it will dramatically help with ride quality.
look to get new bushings, C&C plates (if drop is more then 1 inch or so).
Old May 19, 2006 | 01:59 PM
OnyxCobra's Avatar
OnyxCobra
how many miles are currently on the vehicle and how low is the drop?
Old May 19, 2006 | 02:57 PM
DBovine's Avatar
DBovine
The car has 50,000 or so Miles (81,000kms) and I was looking at the Ford C Springs or IMP DDs. The ford C springs say upto 1.25" but I think they are closer to 1" in the front and 3/4" out back.
Old May 19, 2006 | 03:31 PM
sandcracker21's Avatar
sandcracker21
you wont need anything else besides the springs....ie. no cc plates or struts or shocks
i would urge you to look at the eibach pro kit however, as i dont know if 3/4 of an inch
is worth the money.....you may not even notice that
Old May 21, 2006 | 06:29 PM
rcobra's Avatar
rcobra
I was reading about 1994 and 1995 mustang spring replacement not too long ago, but this may apply to your situation. BBK offers a kit with progressive springs, all four corners, they lower by 2 inches. The OE suspension bushings were replaced with polyurethane bushings to tighten the ride even more. These bushings fit the sway bar, strut mounts, and end links. A set of polyurethene offset steering rack bushings is also added to help raise the steering rack to compensate for the ride height created by the coil springs. By correcting the tie rod angles, bumpsteer is reduced or eliminated totally, critical for a car thats been lowered
See if BBK has a kit to meet your cars specs and needs.
Old May 21, 2006 | 06:35 PM
OnyxCobra's Avatar
OnyxCobra
well at 50k miles u might need to replace or struts and shocks soon anyway, i say go with a larger drop like around 1.5" and then just get some aftermarket struts when urs finally go... I'd also suggest getting CC plates with that drop but I'd just say screw it until you're ready for an alignment )
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
