PLEASE HELP ME IMMEDIATLY
Old May 19, 2006 | 08:15 AM
verter2's Avatar
verter2
Default RE: PLEASE HELP ME IMMEDIATLY
This might sound weird, but I know that in rare occasions a piece of catalyst will break off and either become lodged in the converter or travel down into the muffler. In these instances, it won't nesessarily vibrate/knock/rattle all the time, but in fact will be agitated by a combination of things like exhaust frequency (hence not in neutral but 1 or 3rd) and vehicle vibration (motion). However, when this happens it is almost always in high-milage cars with a worn converter. Just a thought.
Old May 19, 2006 | 09:08 AM
Natex's Avatar
Natex
If you want to rule out your engine get a long screw driver and put it right on the block. If that knock doesn't vibrate through the driver, it's not your engine. Lil shade tree trick.
Old May 19, 2006 | 01:27 PM
ToplessGT's Avatar
ToplessGT
lol, a 35 dollar bearing.. sounds so cheap doesnt it. Unfortunately not that simple man... you will be replacing everything while your in there. You would be stupid not to, as long as the hard part of taking it out is done. Trust me, when it comes to cars, its not ever cheap/easy
Old May 20, 2006 | 01:57 AM
michaelbarry's Avatar
michaelbarry
First thing I thought when I read the title was "universal joint"
Old May 20, 2006 | 02:41 AM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ARDollar, stop being such a douche with the stupid posts all over the tech forums. You're not helping anyone. Go ***** up off topic.
To the thread starter....if You only have 15K on your car, why don;t you get the dealer to look at it. It should be free because of warranty.
Also, if you only have 15K on your car, it is not likely a throw out bearing. They tend to last a little longer than that and your problem would not go away in fourth and fifth or reverse.
Sounds like you have fuggered up a gear cluster in your trans but you can't diagnose something like this over the internet. You need to get it to a pro.
good luck.
Old May 20, 2006 | 08:03 PM
hwest's Avatar
hwest
ORIGINAL: MikeHawke
good luck.
+1!!!
HaV
Nov 25, 2006 11:19 AM
tcoope13
Nov 21, 2006 08:06 PM
uberstang1
Jul 15, 2005 04:08 PM
