Steeda Short Throw
Old Apr 14, 2004 | 08:24 PM
Obsol3te's Avatar
Obsol3te
Default Steeda Short Throw
Installed my Shifter all by myself! Wahoo!
Can't wait to give it a go once I get my car up and running. Maybe I wont miss third as much anymore when racing(I HOPE!!)
Too bad I can't drive it at the moment tho, my distributor is out because the gear is getting changed (leaving it over night because they were busy)from steel to cast iron so I don't chew up my camshaft.
And my headers are partially off and so isn't some of the exhaust. Attempting to put on my LT Headers and Shorty H...
Also, I noticed the previous owner had Flowmaster Mufflers(not sure what exactly I'll try and see if it has numbers on it) on it... I'd like to get those changed, what would be good for the following setup:
BBK 1 3/4" Ceramic Coated Long Tube Headers
BBK 2.5" Shorty H-Pipe w/ High Flow Cats
I want to keep my tail pipes because I like the hidden look, and my back skirt comes down too far anyways.
I'm hearing Magnaflow is a great company for the money, I want sound and performance. What do they got for that?
Old Apr 14, 2004 | 11:03 PM
nhdungeonracer's Avatar
nhdungeonracer
Default RE: Steeda Short Throw
I hope you said this backwards. You want the steel gear on there, not the cast iron gear. It's the cast iron gear that will fill your engine with metal shavings.
I'm presuming you cam is steel as well.
Old Apr 14, 2004 | 11:10 PM
Obsol3te's Avatar
Obsol3te
the ford B303 cam is cast iron...
so i need the CAST IRON gear on there
says right here on the tag:
[ul][*] This distributor is equipped with a steel gear. It should be used only with a billet steel camshaft(roller tappet).[*] All cast iron camshafts (flat tappet) must use a cast iron gear. See MSD Catalog.[*] Bronze gears may be used with either a cast iron or billet steel camshaft. See MSD Catalog.
[/ul]
Old Apr 14, 2004 | 11:15 PM
nhdungeonracer
Ahh, ok. Looks like you're doing the right thing then.
Save that gear though, ok? Never know when you change cams again.
Old Apr 14, 2004 | 11:27 PM
bossman351's Avatar
bossman351
ORIGINAL: Obsol3te
[/ul]
Maybe Im mistaken but I always thought that the 5.0 liter "H.O." came equiped with a roller cam from the factory. Anyone know for sure???
Old Apr 14, 2004 | 11:29 PM
Sean's Avatar
Sean
Yup a roller.
Old Apr 14, 2004 | 11:34 PM
bossman351's Avatar
bossman351
Then doesnt that mean he should use the steel gear insted of the cast one??? At least according to his post. Unless he stated it backwards he says roller tappet = steel and flat tappet = cast. If his car has a true roller motor in it he should use steel. Correct???
Old Apr 14, 2004 | 11:36 PM
bossman351's Avatar
bossman351
Ive always heard that bronze was the way to go anyways.[sm=smiley20.gif]
Old Apr 15, 2004 | 12:22 AM
Obsol3te's Avatar
Obsol3te
Well I have the Ford B303 camshaft, and it's a cast iron camshaft...
so i put 2 n 2 together
Florida Regional Chapter
Sep 30, 2015 08:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 30, 2015 03:48 AM
mungodrums
Sep 28, 2015 10:54 PM
Sep 24, 2015 09:18 PM
