Cooling hood
Old May 20, 2004 | 12:24 AM
VertStangGT86's Avatar
VertStangGT86
Default RE: Cooling hood
Might try a new fan clutch if it's not the waterpump. Cause if you go with something like an electric fan you'd just be putting a band-aide on it and not fixing the real problem.
Old May 20, 2004 | 02:40 PM
FoxGT's Avatar
FoxGT
I'm not using an electric fan, I hate them. The last mustang I had overheated with one (88 GT)
Old May 27, 2004 | 03:51 PM
Turtle's Avatar
Turtle
What about the lower radiator hose? Are you sucking it flat. When you turn high RPM's like on the highway you could be restricting the water flow just like a clog in the radiator would. I had a similar problem. I was overheating during acceleration and cruising at speed. Mine was bad enough that I started blowing gaskets on the water pump. This happens especially with older hoses. Squeeze it and if it feels really soft (especially cold) it could be a quick cheap fix. Only a possibility.
Old May 27, 2004 | 03:54 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
another thing to check for is your gauge working properly, you're temp sensor as well, and that you don't have any air in your cooling system. If those check out good, then look for a bad thermostate, waterpump, radiator, fan clutch, and ignition timing, and fan shroud. Thats all I can think of for now. GOdd luck.
Old May 30, 2004 | 11:27 PM
FoxGT's Avatar
FoxGT
Fan clutch was bad
Old May 31, 2004 | 12:27 AM
VertStangGT86
Ha ha, I win. lol, glad you got it fixed.
Old May 31, 2004 | 07:57 PM
FoxGT's Avatar
FoxGT
indeed [sm=smiley20.gif]
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
