I want to cut my Eibach Sportline's which end to cut?
RE: I want to cut my Eibach Sportline's which end to cut?
ORIGINAL: redass02gt
ROFL
methinks yes.
ROFL
methinks yes.
if it is..I don't get it... money suddenly run out? Or just impatient as hell?[sm=dontgetit.gif][sm=bangbang.gif]
ORIGINAL: Derf00
Are you the same one that wanted to use a spray can to paint part of the hood?
hmm..actually turned out pretty good. Let us know how the paint holds up over time.
I still wouldn't cut springs though. Remove the isolators if you want it lowered. Cutting the springs is just going to ruin their spring rate.
ORIGINAL: Derf00
how much will it lower it if i removed the top isolator as well?
ORIGINAL: amrcnidyot
ive heard that the back ones will squeak a lot but that would be a lot better than destroying your susspension and having a crappy ride
ORIGINAL: OnyxCobra
instead of cutting you should try removing the isolators...
