8.8 Rear end ratio
Old Aug 4, 2006 | 03:43 PM
85mercpark's Avatar
85mercpark
Default 8.8 Rear end ratio
Can someone identify the ratio on this rear end?
Is it a POSI?
Thanks
Old Aug 4, 2006 | 07:57 PM
Jugador's Avatar
Jugador
Default RE: 8.8 Rear end ratio
if you spin the pinion and count how many times the axles rotate, you can get a rough idea of what gears you have (4.10's=4 rotations, 3.73=3 3/4 rotations etc). i believe you can tell it's posi if you spin one axle and the other axle spins the same direction
Old Aug 5, 2006 | 07:57 PM
Decurion's Avatar
Decurion
3L73 means 3.73 ratio, limited slip
Old Aug 6, 2006 | 12:26 AM
Cobrakev's Avatar
Cobrakev
If that is a 8.8 rearend out of a Mustang, that is not a 3.73 rear. No Mustang came stock with 3.73 gears. The older autos had 2.73 gears in them.
Kev
Old Aug 6, 2006 | 12:30 AM
nitrous_bob's Avatar
nitrous_bob
i'm guessing it's from a f150 or 250 w/ the towing package (not really guessing, i'd bet my next paycheck)
anyways, seems to be a 3.73 from those 2 digits.
if it happens to be from a stang you have, check the door tag...under "ax" m=2.73 , z=3.08 , and e=3.27 (aod only)
mtgldr
Feb 3, 2024 09:00 PM
articman
Jun 21, 2018 11:45 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Dragonus18
Sep 9, 2015 01:21 AM
Sep 1, 2015 08:16 PM
