Knock from steering when turning...
Old Sep 25, 2006 | 02:15 PM
tommy_t's Avatar
tommy_t
Default Knock from steering when turning...
Whenever I turn into my driveway I get a single loud knock coming from what appears to be around the right tire. I'm no mechanic, any ideas?
Old Sep 25, 2006 | 03:03 PM
sdmaker's Avatar
sdmaker
Default RE: Knock from steering when turning...
tierod end or balljoint most likely.
Old Sep 25, 2006 | 03:16 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: sdmaker
From the right rear? Is this a 4 wheel steering version?? [8D]
Could be a loose control arm or shock tower. Take out the trunk carpet with the car on the ground and see if the shocks are properly torqued down (35 ft/lbs.)
Jack the car up and check everything in the rear (control arms, bottom shock mounts, rear sway bar etc.)
Old Sep 25, 2006 | 03:20 PM
turbostang21's Avatar
turbostang21
^^^where did he say anything about the rear i would also check the balljoint and tierod. jack up the front of the car...use stands....and see if there is any play in the wheel
Old Sep 25, 2006 | 03:22 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: tommy_t
Oh shiznit..ur right.. [:@] Damn I need more coffee [&:]
Yeah..ball joint, or strut mounting then.
Old Sep 25, 2006 | 03:33 PM
Miliock's Avatar
Miliock
I used to get it when going up a curbcut. It was my upper control arm hitting the aftermarket catback
Old Sep 26, 2006 | 04:00 PM
tommy_t's Avatar
tommy_t
Appreciate the help! I'll check all of the above when I put it away for winter
lincolnshibuya
Dec 8, 2020 01:49 PM
CS2007
Jun 25, 2019 09:45 PM
allenmaty
Sep 24, 2015 09:17 AM
stark777
Sep 21, 2015 12:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
