302-351?????
Old Sep 25, 2006 | 04:23 PM
88blackwidow's Avatar
88blackwidow
Default 302-351?????
Does anybody know, if a 351 clevlend with bolt up in my 88 gt with no problems? And if the throttle body and intake will bolt up to the 351.
Also would i be better off to just but port and polished 351 heads on my 302 or go with a 351, and if i go with a 351 should it be a clevlend, or a windsor, i'v also heard that 351 clevend heads won't fir on my 302 is this true???
Thanks,
buddy
Old Sep 25, 2006 | 11:21 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 302-351?????
It takes a lot of work to install 351C heads on any Windsor block. It really isn't worth while with the heads that are available for the Windsor engines.
No, the 351C is not a bolt in transplant. You would be better off with a 351W, but you will still need the complete engine with a new intake and the accessory belt drive, as well as the right oil pan for your car.
The easiest solution would be a 347 stroker, as it would look exactly like your current engine, but will have the cubes of these 351's. There are several companies that will sell you a long block as a kit or assembled.
karlselle
Dec 24, 2007 10:05 PM
PONY GUY
May 13, 2007 10:59 PM
94RedDevil
May 7, 2007 11:04 PM
pattymelt1285
Dec 15, 2006 05:59 PM
Stangnsnow2
Dec 11, 2006 08:28 PM
