AFR heads with Speed-Pro pistons
hey guys i have a 302 bored .020 and i have these pistons in there:
TRW-L2488F Speed-Pro
Deck height: 8.206 in. Deck clearance: 0.003 in. Skirt clearance: 0.0018 in. Weight: 597g. Approximate compression ratios: 10.51:1 with 54.5cc, 9.99:1 with 58.2cc, 9.72:1 with 60.4cc, 9.41:1 with 63cc
I want to get AFR heads and these are the ones im thinking about getting, but i hear that the pistons need to be notched???? does anyone know if my pistons have to be notched?
AFR# 1388 - 185cc Street/Strip Heads, Stud, 58cc (NON-Emissions) OR
AFR# 1387 - 185cc Street/Strip Heads, Stud, 61cc (NON-Emissions)
2.020 intake valves, 1.600” exhaust valves, combustion chamber volumes of 58cc or 61cc, and 69cc exhaust ports, AFR’s new 185cc Ford head is designed for 302-351 cid engines operating from 1500 rpm to 6500 rpm. A 3/4” thick head deck makes the AFR head ideal for nitrous or blower applications. Will not accept rail rocker arms. Hardened pushrods required with heads #1420 and #1422. High flow 2.020 valves might require aftermarket pistons notched for valve clearance.
Note: Late-Model Ford 302 engines must have stock pistons notched for clearance.
I actually I have a 94 cobra with AFR 185s and a trick flow stage 2 cam with 1.7 roller rockers and I didn’t have to notch anything . The total lift was 575 with that cam and rocker ratio. How ever to be safe I would clay it when you are putting it together. Also make sure that you take the head to a machine shop so they can install spring cup that keeps the springs from digging in to the soft aluminum and changing spring install height
Any more questions fell free to Pm me
Dan
ACTUALLY AFR'S do have spring cups
ORIGINAL: PSR
Dan
Dan
ORIGINAL: grabbem88
ORIGINAL: PSR
Dan
Dan
Dan
I just was talking to Jason from AFR and he was telling me that non of there head had spring cups how ever they all will have them come first of the year right now they are on a 2 month back order. Just incase you were wondering.
PSR
PSR
