Making a noise
Old Oct 8, 2006 | 05:12 AM
pony_stoked's Avatar
pony_stoked
Default Making a noise
Hey guys I was wondering if anyone knew what is going on with a sound that my car makes. The noise is a high pitched sound that sounds like something is winding up. It kind of sounds like the noise when I turn my wheel when making a u-turn, but it mainly makes the sound in the lower gears, when under accelerating. I have no check engine lights on or anything like that. The car pulls like a 1999 V6 should but I just don't know what the noise is. It is just kind of bugging me when I don't have the radio on. If anyone has any ideas on what it could be let me know. thanks.
Old Oct 8, 2006 | 05:14 AM
hammeron's Avatar
hammeron
Default RE: Making a noise
could the belt be slipping
Old Oct 8, 2006 | 05:25 AM
pony_stoked
could be I'll have to really inspect it closer tomorrow with some good light. I kinda looked at the belt but may not have been reving it enough to see it slip.
Old Oct 8, 2006 | 08:58 AM
corvetteguy's Avatar
corvetteguy
I don't believe you can see a
belt slip. If the inner surface
looks checked you should
replace it. Also check lrvel
of ps unit fluid.
Old Oct 8, 2006 | 12:34 PM
Poobs's Avatar
Poobs
Check the power steering fluid
Old Oct 8, 2006 | 11:41 PM
pony_stoked
Thank you guys for the advise. I'm just getting into the whole car thing and don't know much but hope to learn a lot here.
Old Oct 9, 2006 | 05:08 AM
FoxGT's Avatar
FoxGT
could be many things...
Bad ground, causing a whine that sounds like its going with your engine rpm to come out of the speakers. low trans fluid, bad throwout bearing.
I highly doubt it's powersteering, or belt related from the way you make it sound, but it is possible.
Powersteering you can tell by just sitting idling & turning your wheel one way or the other. If you hear the whine you are talking about then that's it.
Belts will usually make a VERY loud screeching noise & when it does it will in most cases go away after a bit of the engine staying at a constant speed.
In any case, it's free to check the ground, just stick your ear up next to one of the speakers & slowly rev the engine see if you can hear it.
Then do the same thing, have the car in neutral, clutch out. Rev the car slowly let the rpm climb & listen for it. Then do the same thing, but this time with the clutch in. If one way it makes the noise & the other does not. It's in your transmission.
Check these for now & let us know what you've found out. If nothing, we'll go further I'll give you a few more possibilities, these are just the most common.
bjdutch2005
Mar 24, 2017 03:38 AM
04stangman
Sep 17, 2015 01:45 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Emblazoned
Sep 3, 2015 10:45 PM
