View Poll Results: A poll
Premium(92ish) - Stock
27.27%
Mid-Grade(89ish) - Stock
13.64%
Regular(87ish) - Stock
9.09%
Premium(92ish) - Modified
50.00%
Mid-Grade(89ish) - Modified
0%
Regular(87ish) - Modified
0%
Voters: 22. You may not vote on this poll
What Octane Gas?
Old Jul 30, 2004 | 01:14 PM
  #21
Dearborn5.0's Avatar
Dearborn5.0
Default RE: What Octane Gas?
leaded gas in the D?
Where?
Old Jul 30, 2004 | 02:51 PM
  #22
roundman's Avatar
roundman
I don't know about the newer Stangs, but my '88 required premium octane fuel from the beginning and it said so in the owner's manual. And once I installed a Hypertech chip on the ECU, I had to keep using 93 octane to make sure it didn't knock under a load. My '88 didn't come with a built in knock sensor either like the newer cars do. Now that it's a race only vehicle, I have bumped the timing up and use 104 octane unleaded Sunoco gas from the track in the tank. Damn stuff costs $3.99 a gallon, but it is worth it in my opinion as it lets me run the engine right on the verge of detonation without it knocking at all.
I would say that you should try running the minimum octane recommended in the owner's manual first and if that causes a problem, then move up to the next higher octane level or adjust the tune-up so it runs correctly on the lower octane.
Old Jul 30, 2004 | 08:25 PM
  #23
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: Dearborn5.0
Where?
I am not sure where, but I can try to find out. I was talking with a streetracer from up there a few months ago and told me he could get it. Here in Chicago it is easy to find, I think of at least 3 places off the top of my head where I can 110 leaded at the pump, and thats just around my area.
Old Jul 30, 2004 | 11:45 PM
  #24
FoxGT's Avatar
FoxGT
leaded gas is bad for cat. converters (meaow) & the O2 sensors, but is good for your engine. It has more detergents & lubricating additives.
Old Aug 1, 2004 | 01:05 AM
  #25
HAUS's Avatar
HAUS
i worked for a sunoco gas station for a while and there was full serve there. you should of seen all the high performance cars there trying to save money and put 87 in it. like this lady with a newer model MB SL 500. puts regular in it. for my 92 lx for says to put 87 in it so thats what i put in it. even with my 2000 gt i put regular in it. one time i needed gas so bad in my 2000 and they were out of regualar so i was forced to put ultra in it which is 94 octane and it ran like crap and it killed my gas milelage.
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
