High Temperature! HELP!
Old Oct 14, 2006 | 05:21 AM
Kirko's Avatar
Kirko
Default High Temperature! HELP!
My fan works, and my thermostat works because my heat and everything is fine. so i cant understand why my car is getting over heated. anyone know?
Old Oct 14, 2006 | 09:42 AM
corvetteguy's Avatar
corvetteguy
Default RE: High Temperature! HELP!
How did you determine that your
thermostat is working?
From overnite parking, start car
and let it warm up.
Watch temp gauge (5 minutes or more)
It should go up past normal and then
take a nose dive down and back to
normal.
If it stays up you got a shut thermostat.
You will always have heat in the car.
Old Oct 14, 2006 | 10:43 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: corvetteguy
and let it warm up.
normal.
Not true, if there is no circulation, there will be no heat.
Kirko, can you be a lil more specific about what's going on?
Old Oct 14, 2006 | 01:28 PM
5IVE.OH's Avatar
5IVE.OH
Any white puffs out the exhaust?
Old Oct 14, 2006 | 01:44 PM
Doomtroop's Avatar
Doomtroop
My car was overheating a year ago and it was because the cooling liquid was expired. Maybe it could be related to that ?
Old Oct 14, 2006 | 01:48 PM
kylebgt's Avatar
kylebgt
If your thermostat is stuck in the closed position your heat will still work, it is your a/c that wont be working.
Old Oct 14, 2006 | 01:49 PM
Kirko's Avatar
Kirko
^ Yeah a lot of white smoke coming from the exhaust and water too when I start the car after it sits a long time.
Like I just got it and I was going to flush the radiator change the oil. change the antifreeze etc.
I went to flush the radiator. just turned the car on for the first time that day so the engine was cool. the water was at the top of the pipe where u open and it would stay like that until i gas it then it goes down but then it comes back up. it shouldnt do that or atleast i dont think so. my other cars didnt do that until the engine got hot.
when i turn my car on it gets hot then the fan isnt running. then my fan will quick in a little later and it will cool down but then the heat will go back up after im driving a couple/few miles.
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
Drastang
Sep 30, 2015 03:48 AM
mungodrums
Sep 28, 2015 10:54 PM
