ate 3 belts in two days
So i was goin to the store and i opened up the the trhottle really hard. i floored it through first and second then pulled up to a light and then floored it through first. once i let up i herad this horrible noise. i had peeled my belt and some of the ribs were flailing around and whipping the under side of my hood. Any way i had the car towed to a show where they put on a new belt. we started it up and with a little bit of gas, it shredded that one too. we found that it was a bad pully and some lose screws. so we tightened everything up and put another belt on. they said id be fine until they puly they ordered came in. halfway home, the new belt comes lose! the steering wentout, the batter stopped charging -the belt wasnt touching anything! i was pissed but the left the shop in a truck and tightened it up for me on the side of the road. i rove home and as i got in my neighborhood, horrible belt squeek started. i drove it back to the shop the next day where they gave me a new pully and another belt.
Now, when i rev my engine to redline (7K) in neutral, the belt squeeks. i asked them about this and they said i shouldnt rev in neutral because it damages the belt. WTF? i asked how am i supposed to drive fast if I cant rev it high and they told me to give it about a week to break the belt in. Whatn do you guys think? Should I really have to "break in" a belt or are they BSing me and just hoping that my belt wont peel again?
high rpm, with no load = flying pieces of engines nono very bad
also the belt will lost that shiny coating and shoudlnt squeal any more after about 100 miles.
i hope you checked all the other pullies to make sure none are seizing up. think they all got the same wear on them, only 1 going bad ?
Spray some brake cleaner on the pullies while the car is running. When youre doing this itll squeal like crazy, then it should go away after a few seconds. BTW, the pully WILL shoot brake cleaner back at you so at bare minimum wear some safety glasses or better yet a face sheild.
The brake cleaner is actually a degreaser, it should remove any unwanted oil, coolant, atf, etc from the pullies surfaces.
-P.
PS: You might have to repeat this process several times.
-P.
You have to break a belt in?[sm=bs.gif] Right before I race my car I put a new belt on, this way its not stretched out at all and I get no belt slip with the supercharger.
You can rev as high as you want in neutral the computer has a built in rev limiter that will only allow it to go so high in neutral, unless you had this removed via a tune. Something has to be wrong with your pullies as mentioned before.
Shredding belts like that is usually a sign of a bearing failure.One of the bearings has or is failing and can't keep the belt in line with the other pullies.As the belt rides up over the outer rib,it tears and fails.
Look at one of the idler pulleys as a likely suspect.
Spraying brake cleaner into any bearing washes the lube out and will cause early failure.
You can use a long wooden dowel or screwdriver to listen for rough sounding bearings.Anything but a smooth sound coming out is a sign of impending doom.
ORIGINAL: dapack69
Yes you do have to break a belt in, the importance of it is minor though, but if you throw a new belt on there and go for a day at the track right away there's a pretty high chance that belt isn't going to stay on, especially in a supercharged application. The belts do stretch a little as they wear in.
Like it's been said, you may have a bad pulley, the idler pulley on the 4.6 stangs is known to go bad. Mine threw a belt stock at 11,000 miles, I replaced the belt and it's been fine for another 15,000 miles. Anyway, if the squeak isn't gone in a week, the tensioner may need to be tightened up a bit.
haha yes the engine is totally built as well as the transmission and the rear end. The wooden dowel trick worked on the pullies and the idler pully as bad. We replaced it but when doing so, noticed abnormal wear on the little **** on the timing chain cover that it sits on. Is this OK? I replaced the belt and the pully and the squeak is gone now, I just dont want another nasty suprise. PS the rev limiter is set at 7k.
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
