Moisture
Old Nov 18, 2006 | 09:34 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Moisture
First, you need to dry out the inside. Then, you need to find where the moisture was getting in. Having a vent in the housing isn't really a bad thing, as these models are known for the moisture problem.
Or, move to a low humidity area...
Old Nov 19, 2006 | 04:12 PM
MustangMike2001's Avatar
MustangMike2001
Obviously the rubber seal is not fine or it wouldn't be letting moisture in. You need to wait till they have dried out and then run some silocon along the rubber to seal it off.
Old Nov 21, 2006 | 01:48 PM
65coupe88hatch's Avatar
65coupe88hatch
I put the small hole in the bottom..it allowed the water resting at the bottom to release out of it but theres still that annoying mist like water on the lens...anymore suggestions?
Old Nov 22, 2006 | 08:55 AM
corvetteguy's Avatar
corvetteguy
Good.
You took the first step.
Now time will do the rest.
The heat generated by the lites will
dry it out.
Old Nov 22, 2006 | 01:08 PM
MustangMike2001
Yeah lets take advice from a guy with a wooden floorboard.. Seal up your lenses and quit bitchin about it.
4cylinderplus2
Oct 9, 2020 07:45 PM
Nitti00GT
Oct 29, 2006 09:36 PM
mightyb28
May 31, 2006 09:43 PM
razarr69
Oct 15, 2005 03:41 AM
rockin95
Sep 26, 2005 02:07 AM
