casting numbers and interchangability
Old Nov 17, 2006 | 03:55 PM
RedandBlack's Avatar
RedandBlack
Default casting numbers and interchangability
firstoff, ive got myself a 351 windsor that im rebuilding. The original cylinder heads had a couple of sunken valves and they both ended up being cracked, so im looking around for some other ones. the factory ones have a casting number of E7TE and i know theyre from a truck engine in the 80s, but ive found some that i think are from 1970. they are from a 302 and the casting numbers are D70E or possibly D7OE. Ive checked them out and all the coolant passages are the same. the only difference i can tell is that the ones from a 302 have a bigger combustion chamber. im almost positive they are interchangable, but id rather have someone on here confirm it. . also if anyone knows any good links to any good sites to translate ford casting numbers or also any sites that explain which parts are interchangable between the 289/302/351w. thanks a lot.
Old Nov 18, 2006 | 04:31 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: casting numbers and interchangability
351W uses larger diameter head bolts.
Old Nov 20, 2006 | 03:50 PM
RedandBlack
is it possible to ream the holes in the head to fit the head bolts?
Old Nov 20, 2006 | 10:00 PM
shokwave30's Avatar
shokwave30
u have a PM..
are the valves the same size?
Old Nov 22, 2006 | 03:48 AM
Colorado_Mustang
I would take them to a machine shop and ask them. I haven't done this myself.
ORIGINAL: RedandBlack
bconboy
Sep 24, 2015 01:55 PM
jstrothe
Sep 24, 2015 12:17 PM
Sep 23, 2015 01:28 PM
2016PP
Sep 23, 2015 09:51 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
