Removing dashboard from mustang 03
RE: Removing dashboard from mustang 03
remove all under dash pannels, then disconnect wiring, finally there are 4 nuts holding the steering whel on the dash, remove them..
now remove center console, glove box door, and reach inside and disconnect the wiring on that side and the ac controlls,
now that thats out of the way, there is like 5 bolts on the top. under the defroster plastic thingy 8 mm if i remember, now look into the glove box on the far right there is like 1 bolt remove that, now 4 bolts holding the dash to the center console bracket, got them! !
final bolts are drivers side 2 of them a large one (cant rememver if nut or bolt ) look thru where the fuses are , should be behind there, and 1 more below it
thats it now take 2 people and lift that biotch out without denting or scratching anything
reverse to install, just remember have someone help you hold it up in place while you install or it will not be seated correctly and nothing will match up to it
if you have any questions pm me
thanks
mark
thanks
mark
