convertible problem
Old Nov 30, 2006 | 08:48 PM
tuneskies's Avatar
tuneskies
Default convertible problem
When i push/pull the switch i can hear the motor, but nothing happens. What could be wrong with the top?[&:]
Old Nov 30, 2006 | 08:50 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: convertible problem
Sounds like somethings broke! Try the forum at the top. I think you posted in the wrong section!
Old Nov 30, 2006 | 08:54 PM
GreyStang's Avatar
GreyStang
Is it making the noise when you open it or close it? Does it go all the way if you give it an assist with your hand?
Old Nov 30, 2006 | 10:29 PM
tuneskies's Avatar
tuneskies
it does absolutely nothing except make a noise.
Old Nov 30, 2006 | 11:01 PM
wythors's Avatar
wythors
If the motor's running, you more than likely have a hydraulic problem. Pull out the back seat bottom (grab the front of it and pull up) and see if there is any hydraulic fluid running out from underneath the seat back. You may have a broken line. Or, the pump may have taken a dump on you. You're going to have to do a little digging. If there's nothing under the seat, take out the rear seat back to access the mechanism. There is a bolt in each lower corner of the seat back, kind of up underneath the cushion. Take those two bolts out and pull down on the cushion. It will come right out. All of the workings for the top are right there.
ohfarrell
Oct 18, 2015 11:27 PM
musnicki
Sep 23, 2015 07:11 AM
spamedic
Sep 9, 2015 12:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
