460 big block fit?
Old Dec 7, 2006 | 02:58 PM
blitzed589's Avatar
blitzed589
Default 460 big block fit?
Would a 460 big bock fit under the hood of a 04 Gt without any major adjustments?
Old Dec 7, 2006 | 04:47 PM
jknoxville456's Avatar
jknoxville456
Default RE: 460 big block fit?
You would have to mod alot of different things fairly heavily. a 460 is a really heavy motor and has relatively low performance for its size. I think they are the worst motors Ford made, but don't let my opinion keep you from doin it. I'd be interested in seein a finished product.
Old Dec 7, 2006 | 04:57 PM
Archion's Avatar
Archion
If you want something that size, go with a 429 with pre 71 heads and cam, will be a lot better off. As far as it fitting, back in 94, ford did a boss 429 with out too many fittment problems, hell it looked right at home, but had to do a hell of a lot of suspension mods. As far as width itts not too bad, look how wide the damn 4v mod motor is. You would be custom fabricating quite a lot of stuff, and probably have to go with a hydro-boost brake system etc.
Old Dec 7, 2006 | 05:51 PM
JBradley500's Avatar
JBradley500
it won't pass inspection under that hood...unless your a drag racer.
Old Dec 8, 2006 | 12:29 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Easily. The chassis may have to be strengthen to handle the power, but it would work for a mild 460. The K-member would be the biggest stumbling block. But, a bit of engine mount fabrication for that and the tranny and you'll just need a big hood.
And, the 385 series big block will gladly run circles around just about every other Ford engine made. Yes, it's heavy, but it more than makes up for it with power.
ORIGINAL: blitzed589
Old Dec 8, 2006 | 12:36 AM
PSR's Avatar
PSR
I have done this conversion only once and right off the trailer the car went 10.7 you can find the change over stuff at summit or jegs parts also Mac Performance offers a set of headers for this application you would need to get a 94-95 tube k member, good luck and keep us up dated
Dan
Old Dec 8, 2006 | 11:08 AM
blitzed589's Avatar
blitzed589
yeh, thanks for the input, i havent made a decision on which engine yet, lots of options.
Old Dec 9, 2006 | 06:29 PM
Colorado_Mustang
514cid would work well. Maybe a blower to help it out a little bit...[sm=americanasmiley.gif]
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
