what year mustang
Old Dec 9, 2006 | 02:24 PM
oldskool69's Avatar
oldskool69
Default what year mustang
im looking at a couple years, 87, 88, 89 and 93's. but im not to sure is there anything i need to know bout any of thoes year, like problems or drive train!
Old Dec 10, 2006 | 04:51 AM
Waderacin's Avatar
Waderacin
Default RE: what year mustang
Just skip those years and buy my 96 GT. There basically the same vs. options.
Old Dec 10, 2006 | 07:59 AM
Dan04COBRA's Avatar
Dan04COBRA
Barely the same. The 5.0 will actually respond to mods & won't be restricted to being a 230rwhp turd for the duration of it's life without a head/cam swap + a tune which would total out to be double that of a similar swap on a 5.0.
Oldskool, the car is going to be old and more than likely driven hard more times than you would want to know. It'll suffer typical Ford issues, TOB's, need to be gentle with the tranny, typical Ford stuff like I said.
Old Dec 10, 2006 | 03:45 PM
alexr's Avatar
alexr
dont get a 93 unless you have to. 93 5.0's were rated at 205bhp where as the rest of the aero 5.0's were rated at 225bhp
not too much of a big deal, but if you have the option, id definitely choose another year than 93.
Old Dec 10, 2006 | 04:09 PM
Colorado_Mustang's Avatar
Colorado_Mustang
The engine is the same. The only difference was Ford's decision to list the minimum HP of their sample versus the average.
ORIGINAL: ARdoller
Old Dec 11, 2006 | 01:53 AM
illdrag's Avatar
illdrag
ORIGINAL: Colorado_Mustang
ORIGINAL: ARdoller
there were a couple differences in years...
86-88 used speed density instead of mass air wich does not respond to cam changes well...but were the fastest n/a
87-93 used mass air wich used a meter to read the incoming air instead of the map sensor..really easy to modify and very inexpensive to go fast if you choose the right combo..
and as for 93 the big differnce in the motor was that they used hyper pistons..wich people frown apon for power adders.. i myself have (2) 93 mustangs.one running 10.0s on a stock 93 bottom end motor
Old Dec 11, 2006 | 02:38 AM
Colorado_Mustang
ORIGINAL: illdrag
ORIGINAL: ARdoller
86-87 used speed density instead of mass air wich does not respond to cam changes well...but were the fastest n/a
88-93 used mass air wich used a meter to read the incoming air instead of the map sensor..really easy to modify and very inexpensive to go fast if you choose the right combo..
Fixed. Don't buy a Stang unless it's 88-93 or 99+ or has a carb.
Diode Dynamics
28
May 26, 2022 12:02 PM
Jan 6, 2016 07:03 PM
robjh22
Aug 17, 2015 07:35 AM
daytooday
Aug 11, 2015 09:22 AM
Mr. D
Wheels & Tires
Aug 8, 2015 05:43 AM
