What is my rear end gear ratio
Old Sep 5, 2004 | 08:14 PM
ihrdthattoo's Avatar
ihrdthattoo
Default What is my rear end gear ratio
does anyone know how to find out what rear end gear ratio you have? Don't you count how many times the wheels go around when the driveshaft turns twice????????
Old Sep 5, 2004 | 08:56 PM
2001_SaleenS281_08's Avatar
2001_SaleenS281_08
Default RE: What is my rear end gear ratio
what year and model do you have?
Old Sep 5, 2004 | 09:15 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
Is there a tag on the diff cover? Should be on there. Or you can pull the cover, the ratio should be on the ring gear. Or, you can put the car on stands, rotate the tire one time and count d-shaft revolutions.
Old Sep 7, 2004 | 11:55 AM
pichinco's Avatar
pichinco
ORIGINAL: ihrdthattoo
Depending on your year...the following list defines how to decode your door tag axle code:
DRIVE AXLE IDENTIFICATION CODES:
Axle Code A7 Differential Type Conventional Gear Ratio 3.07
Axle Code E Differential Type Conventional Gear Ratio 3.27
Axle Code E Differential Type Traction-Lok Gear Ratio 3.27
Axle Code M Differential Type Traction-Lok Gear Ratio 2.73
Axle Code Y Differential Type Conventional Gear Ratio 3.08
Axle Code Z Differential Type Conventional Gear Ratio 3.08
Axle Code Z Differential Type Traction-Lok Gear Ratio 3.08
Axle Code 5 Differential Type Conventional Gear Ratio 3.27
Axle Code 8 Differential Type Conventional Gear Ratio 2.73
Axle Code 34 Differential Type Conventional Gear Ratio 3.27
This will only tell you what the car came with of course. NOT what is currently installed. You'll have to resort to the roundman method (see:https://mustangforums.com/m_216023/m.../tm.htm#218568) or look for the tag as Grimace said.
Old Sep 7, 2004 | 02:02 PM
roundman's Avatar
roundman
try this method
https://mustangforums.com/m_216023/tm.htm
Old Sep 7, 2004 | 10:21 PM
vfast's Avatar
vfast
I ♥ Acer
what rpm @ 60?
Old Sep 8, 2004 | 09:39 AM
pichinco's Avatar
pichinco
hehe sorry roundman. I seemed to have forgotten to link it. Good thing I got you watchin' out for me. hehe
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
Sep 1, 2015 08:16 PM
inyadreems
Aug 21, 2015 09:10 AM
91StangOwner
Aug 20, 2015 11:34 PM
