Wheel Spacers
Old Jan 3, 2007 | 09:28 PM
dualstangman's Avatar
dualstangman
Default Wheel Spacers
I need some help figuring out the correct wheel spacers that I need. I have a '65 V-8 Mustang and have '95 Bullitt/ American Racing Torque Thrust II's Wheels. They are 235/45 ZR17's. I want to put the 17's on the 65. Any help would greatly be appreciated. Can I put 95' wheels spacers on it?
Old Jan 4, 2007 | 12:22 AM
jmac72187's Avatar
jmac72187
corner carver
Default RE: Wheel Spacers
You need to know the offset of the wheels. As long as the bolt patterns match and they don't hit the breaks, they will work but they may look awkward if they are pushed into the car because of the offset. Just make sure you get hubcentric spacers so that you don't snap your studs.
Old Jan 5, 2007 | 02:50 PM
lizzyfan's Avatar
lizzyfan
Underboss
Stay away from wheel spacers, plain and simple. It's all to do with the law of physics!!!
Old Jan 5, 2007 | 03:29 PM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: lizzyfan
Hubcentrics are safe because they are putting the weight on the hub and the same spot that the wheels would be putting the weight on. If you get the spacers that are literally just spacers and no studs, you will snap the studs.
Old Jan 8, 2007 | 05:32 AM
peter418's Avatar
peter418
if i was going to put 10.5's in the rear on a 98 cobra, would the wheel be wide enough to fill that space??? i want that flush lookor flusher look.
Old Jan 8, 2007 | 11:01 AM
jmac72187's Avatar
jmac72187
corner carver
Yes they would be wide enough. I think that is the widest you can go.
Old Jan 8, 2007 | 09:10 PM
dualstangman
So how would I make an accurate measurment to find out the offset?
Old Jan 8, 2007 | 11:42 PM
jmac72187's Avatar
jmac72187
corner carver
Offset = Rear Spacing — Total Wheel Width [align=center]2[/align]
Old Jan 9, 2007 | 09:02 PM
dualstangman
?Huh? I'm a little confused.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
