water pump?
Old Jan 6, 2007 | 06:54 PM
DKGreenMetallic98's Avatar
DKGreenMetallic98
Default water pump?
I got a slow leak in the water pump. does anyone have any tips when replacing it? I have a '98 3.8L. pretty high milage if that makes a difference (104K).
Old Jan 6, 2007 | 07:21 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: water pump?
Keep track of the bolts as you take them out. Clean all the mating surfaces thoroughly (wire brush and razor blade scraper work wonders). When installing the bolts, a little sealant/anti-seize is a good choice for the bolts that go into or through a water jacket.
If your bolts are too rusty, go ahead and buy a new set of bolts.
Old Jan 6, 2007 | 09:41 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
get a scotch brite pad to make sure all the gasket material is removed, it really helps. Check your belt too, now would be a convenient time to replace it along with your hoses. One other thing, get a thermostat and go ahead and replace it, and run a coolant flush through there.
Ryan
Old Jan 7, 2007 | 12:05 AM
Lizardbreath's Avatar
Lizardbreath
ORIGINAL: RyansQuick6
Ryan
Pretty much everything this guy said accept I would also get a new set of H20 pump bolts for your car.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
