Posi trac!
Old Jan 19, 2007 | 01:15 PM
mustangman02232's Avatar
mustangman02232
Default RE: Posi trac!
ford will not put a trac lok in the v6s because they use the 7.5 rear end, the 7.5 tlok has weak spider gears and was originally designed for the bronco2/ranger with 120 HP, a hard clutch drop on a tlok will break it and ford didnt want to have to do warrenty work on them
Old Jan 19, 2007 | 09:05 PM
NewMustang's Avatar
NewMustang
ORIGINAL: mustangman02232
What does this 7.5 mean? Gear size? Why can't they put the same trac lock unit that's on the GT on V6's?
Old Jan 19, 2007 | 10:03 PM
mustangman02232
the size of the ring and pinion, the v6 uses a 7.5 inch, which is smaller then the GTs(8.8) you would need to swap in a whole GT rear end, or just put in a true trac in your stock 7.5 diff
if you want to add lsd, i would suggest gears to, mpsautosalvage.com has used 3.73s for $50 which cannot be beat, you just need a bering kit and something to correct the speedo with
scenicnights
Feb 3, 2016 09:43 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
Sep 16, 2015 07:53 PM
fastbackford351
Sep 12, 2015 09:42 AM
Sep 1, 2015 08:16 PM
