Headlight Problem
Old Feb 9, 2007 | 05:05 PM
PR23's Avatar
PR23
Default Headlight Problem
I have a 98 V6 Mustang. Been having a problem that is progressively getting worse. After the car has been running for atabout 15-20 minutes or more, the headlights (low beams) will just turn off. If I pull in on the dimmer lever for a few seconds (4-5) the low beams will come back on. Then a few minutes later, same thing happens again. Any suggestions/ideas would be greatly appreciated!
Old Feb 9, 2007 | 05:11 PM
samseed101's Avatar
samseed101
Default RE: Headlight Problem
Gotta say I've never seen anything like that before. Sounds like either a bad switch or a short near that area.
Old Feb 9, 2007 | 06:30 PM
GreyStang's Avatar
GreyStang
You've got a short & you're tripping the thermal breaker.
Try pulling on of the headlight bulbs out & run with just the other side,, do this test during the day lol. Do the lights still die? you gotta narrow down the area of the short
Old Feb 9, 2007 | 06:46 PM
PR23's Avatar
PR23
THANX! Let's say I run the "remove one headlamp bulb" test on each side and I get the same result..... Any suggestions on what to try after that?
Sounds as though I have an interesting weekend ahead of me.
StalkerGT
Nov 28, 2015 03:09 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
