engine cleaning
Old Feb 16, 2007 | 02:37 AM
boeing747arowair's Avatar
boeing747arowair
Default engine cleaning
so today i cleaned out my engine and it started right up and i ran it for 15 mins. Tonite i took it for a ride and it idles fine and all but it hesitates when i step on it.. any ideas?...
Old Feb 16, 2007 | 05:06 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Default RE: engine cleaning
Water may have pooled on the motor and got into the electronics of the car after start up the second time. Give it more time to evaporate and if that doesn't work try getting the fuel injectors/ fuel pump/ fuel filter changed or cleaned. Just go out and put a bottle of fuel injector cleaner in a new tank of gas. This maybe just a coincidence or water in the fuel system. Later J
Old Feb 16, 2007 | 04:54 PM
NeoTokyo's Avatar
NeoTokyo
I cleaned the 300ZX's engine with that foaming crap that you can spray off, I covered as much electrical as possible but some still seeped through.
It took about 1 week to make all the water evaporate, it will probably take you just as long, running the engine for a while to heat it up will help a lot.
Our problem was that some water got down next to the spark plugs and was causing an arc, among other things.
Best of luck.
-Eric-
Old Feb 16, 2007 | 07:16 PM
v6stang07's Avatar
v6stang07
it will def do that if u got water in the fuel system a little, i would add some fuel injection cleaner, maybe add some 93 octane and let the car rest for a little to see if the water evaporates if its on the electrical
Old Feb 17, 2007 | 02:16 AM
boeing747arowair
yea i figured it out lol when i was cleanin the valve covers with a rag i poped out the plug on #5. its all good now! gthanks alot
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
5.0 kevo
Sep 3, 2015 06:24 PM
Sep 1, 2015 08:16 PM
